Netgear DG834N problem
thedutchman
Plettenberg Bay
Hi guys, so a couple of months ago i bought this moment and today, i got the time to just install this little thing. But i cant get it to work. I plugged in everything, i inserted the username and password but it's just not working. Does anyone here know what to do ?
would really appreciate the help
thanks
NETGEAR issue
you have not given us much to go by, are you connecting with lan cable or only wireless? Have you pinged the router, have you checked if the DHCP is on or off, what other equipment do you want to run on this connection....... need more information
You say you use linux? What does your nessus or wireshark say?
Ek sal jou graag wil help maar ja.... dit is so effens moeilik met die verduideling wat jy gegee het :)
I am going to assume that you are connecting to router locally since you say you have entered your logon name and password already.
Next steps:
1. Check that the WAN light is on steady green.
If not - check phone line connections and/or call telkom to ensure your adsl line is in fact working (Good luck with the telkom 1) :eek:
2. In the router setup - ADSL settings verify that these settings are set to the following.
Multiplexing method - LLC-BAsed (default is VC-based)
VPI - 8
VCI - 35
Let us know
