D3x!
Banned
Hi All,
Just wanted to know if there is a better option to replacing the Netgear DGN2200, i.e do i buy another one or is there another option i should be looking at that does the same or better at the same or lower price?
Thanks.
(basically i just have max 2 pc's connected and 2 ipads via wifi, i like the longer wifi range that this model gave.)
Thanks.
