Netgear wireless
arabbess
Durban
Have ADSL and a NETGEAR router. Can only connect to local only with wireless. Netbook wireless worked fine at the airport and could connect to internet etc. Anyone else had this problem.
Here are details:
Netbook: HP 5101, Windows Vista 32 bit
Telkom ADSL, Netgear, DG834GU V5,
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
Windows IP Configuration
Host Name . . . . . . . . . . . . :*********
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter Broadband Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadband Connection 2
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 165.146.192.159(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 196.43.38.190
196.43.42.190
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Marvell Yukon 88E8072 PCI-E Gigabit Ether
net Controller
Physical Address. . . . . . . . . : 00-26-55-C8-D6-E8
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2d1c:3328:dd99:9e42%9(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, December 12, 2009 7:14:24 AM
Lease Expires . . . . . . . . . . : Sunday, December 13, 2009 7:14:24 AM
Default Gateway . . . . . . . . . : 10.0.0.2
DHCP Server . . . . . . . . . . . : 10.0.0.2
DHCPv6 IAID . . . . . . . . . . . : 234890837
DNS Servers . . . . . . . . . . . : 10.0.0.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom 43224AG 802.11a/b/g/draft-n Wi-F
i Adapter
Physical Address. . . . . . . . . : 00-26-82-1B-C3-F5
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{2C9C0E85-1EB2-43B7-AE80-91B8AB478
C99}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:10.0.0.3%15(Preferred)
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.{9B5CEF61-EBEA-485D-A691-0A697C33D
EB7}
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : isatap.{698C52F0-5E51-45FA-BCAB-C8C98E2A5
64A}
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Link-local IPv6 Address . . . . . : fe80::200:5efe:165.146.192.159%22(Preferr
ed)
196.43.42.190
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : 6TO4 Adapter
Tunnel adapter Local Area Connection* 12:
Tunnel adapter Local Area Connection* 13:
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #4
Temporary IPv6 Address. . . . . . : 2002:a592:c09f::a592:c09f(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
196.43.42.190
Well, the question should be if you are using fixed IP's at home, or DHCP?
You say your laptop can connect to the wifi, but you get no Inet?
When connected to the wifi, can you ping the ADSL router?
Is your ADSL in bridged mode or not? I think it should not be for this set-up.
Is your Netgear in briged mode? It should be.
All for now.
All for now.
Thanks - will try fixed IPs
i dont see the regular netgear "192.168.0.1" ip anywhere.
is this telkom modem different to the dg834g ?
can you access the modem settings and what ip do you use when/if you do?
have no idea what is happening now..uplugged my network cable..and left the wireless on..and still able to post on here..think wireless just kicked in..didn't changed any settings tho..
ok. weird. explanation pls..in non IT terms.
restarted my laptop. connect to wireless. no internet. connect to broadband connection without the cable successfully..then able to surf. what am i missing..
:confused:
