Netherlands IP latency and packet loss
Nephew_
I am having lower latency and packet loss to this IP in Netherlands
185.52.2.59
(I have no other issues with my fibre)
Ping and traceroute
99 packets transmitted, 96 received, 3.0303% packet loss, time 27939ms rtt min/avg/max/mdev = 166.290/253.054/518.494/129.234 ms, pipe 2, ipg/ewma 285.088/186.494 ms $ traceroute 185.52.2.59 traceroute to 185.52.2.59 (185.52.2.59), 30 hops max, 60 byte packets 1 * * * 2 165-73-14-41.ip.afrihost.co.za (165.73.14.41) 5.165 ms * * 3 169-1-21-232.ip.afrihost.co.za (169.1.21.232) 4.451 ms 169-1-21-28.ip.afrihost.co.za (169.1.21.28) 4.936 ms 169-1-21-232.ip.afrihost.co.za (169.1.21.232) 4.830 ms 4 169-1-21-233.ip.afrihost.co.za (169.1.21.233) 4.218 ms 4.339 ms 169-1-21-232.ip.afrihost.co.za (169.1.21.232) 4.895 ms 5 206.249.2.73 (206.249.2.73) 4.818 ms 4.759 ms 5.084 ms 6 * 206.249.2.73 (206.249.2.73) 4.062 ms 3.760 ms 7 be2385.ccr21.lon01.atlas.cogentco.com (154.54.40.93) 181.718 ms be2869.ccr42.lon13.atlas.cogentco.com (154.54.57.161) 160.404 ms 160.384 ms 8 be2870.ccr41.lon13.atlas.cogentco.com (154.54.58.173) 170.482 ms be2869.ccr42.lon13.atlas.cogentco.com (154.54.57.161) 160.060 ms be2870.ccr41.lon13.atlas.cogentco.com (154.54.58.173) 170.296 ms 9 te0-0-2-0.nr11.b061555-0.rtm01.atlas.cogentco.com (154.25.10.134) 188.347 ms be3383.rcr21.rtm01.atlas.cogentco.com (154.54.57.254) 177.435 ms be3382.rcr21.rtm01.atlas.cogentco.com (154.54.39.218) 168.142 ms 10 te0-0-1-0.nr11.b061555-0.rtm01.atlas.cogentco.com (154.25.10.130) 179.530 ms 177.623 ms te0-0-2-0.nr11.b061555-0.rtm01.atlas.cogentco.com (154.25.10.134) 177.652 ms 11 weservit.demarc.cogentco.com (149.6.110.34) 177.198 ms 177.448 ms 177.553 ms 12 * * *
Smokeping graph. Issue started Sunday
Have little joy on my ticket:
IAI-938-23861
185.52.2.59
Ping and traceroute
IAI-938-23861
Hi
I ran a trace route from Centurion now and it looks fine on my side but might be that the issue is resolved now. Can you re-test and see if you are still experiencing the issue? If possible can you do a reverse mtr from the server to your IP or 169.1.1.25 and post the results?
Thanks so much, it seems resolved now. I was "kicked" yesterday just after I posted, I guessed by you :)
Then it follows a new route which is better?
You can see the improvement here:
