NETLIMITER HELP!
Zah1
Hi, having a problem with my data bundles, can't understand why its getting used up so fast. I switched off automatic Windows updates. Maybe that was the problem. Anyway, I read something about Netlimiter being good for checking where the megs are going.
There are so many versions out there. I'm using Windows XP, so which do you recommend? My husband doesn't have a clue, was hoping you guys could help me out! If possible, PLEASE post a direct link. Many thanks!
Thanks for the responses. I downloaded the monitor version, its now sitting in my downloads folder. When I click to open, nothing happens. What am I doing wrong?
