You should be good up to around 100M at 100Mb/s with normal CAT5 cable before experiencing cross-talk. Just keep it away from power circuitry for best results.FxpForce said:I need to setup network between 2 pc's, distance would be +-50m, cant use wireless LOS is crap. Will it work? The long distance ? Anyone done just long cable ?
