Network help
tyerone
Hi all
What is the cheapest and easiest way to limit the bandwidth Bering used by one device / port on the network
My router doesn't have to functionality to do it, need to add something to do it so need advice on what to get?
Hi @tyerone
In my opinion the cheapest, easiest and value for money for home usage*, considering you already have a router that can provide wifi:
The MikroTik hAP Mini:
You would then use this as your primary router/firewall directly connected to the fibre/wan, and repurpose the existing router as a Wireless AP, connected in bridge mode.
Configuration of the MikroTik isn't that difficult, however it may take a bit to wrap your head around, and I would be happy to assist you via DM if you get stuck.
*Note I would recommend using the hAP ac2 instead if you have a line speed above 50Mbps.
Kind Regards,
Jeandre
