RobbJosh
Howzit guys,
I brought a HTC Aria in the USA on AT&T network. I came back to SA and rooted my phone put Android v2.2 on (phone came with v2.1) thinking that would unlock the phone, but it didn't. I ended up looking on the net for a website that I could get an unlock code for my phone. Long story short, I found one, paid for it and it worked. I'm using the phone on Vodacom no matter what I do I can't get 3G or HSDPA to work, only GPRS. HSDPA and 3G work fine in the states.
After doing some research I noticed that in the Mobile Network settings on the phone there is 3 options under Network Mode:
1. WCDMA only
2. GSM only
3.GSM / WCDMA auto
Now from what I've seen I need to use WCDMA to get the 3G / HSDPA to work, but when I select option 1. I don't get any signal and then phone eventually switches to GSM automatically. I was at work on the weekend helping a customer with her laptop and she had a 8•ta 3G modem, and 8•ta 3G modems are currently running off of MTN's network I was told this by an 8•ta technician and I noticed when connecting the modem it said something regarding WCDMA.
So now my question, if I change to MTN do you think I will be able to use 3G / HSDPA on my phone?
Any info regarding this will be greatly appreciated.
1. WCDMA only
2. GSM only
3.GSM / WCDMA auto
