doublefrangelico
- Oct 25, 2005
OK Sometimes I have a good response playing Guild Wars and sometimes it just is too laggy.
In both these instances, the measurement on UtTracestar is constantly between -78 to -80.
Also, whenever my IBurst is laggy with Guild Wars, I dial up using Bluetooth to my phone and GPRS to MTN. This works fine. (a handy tip for those GW addicts)
Also, in both instances, the transfer rate is the same(I know this has nothing do with latency, but just throwing it in there...)
So the problem isn't with the GW servers or the international link in those instances. (unless IBurst uses a different intl. link?)
So taking that into consideration, here's my theory:
WBS towers or proxy servers or something at WBS is causing the bad latency?
- If the modem signal is constant in both instances
- and if the Connection to GW via GPRS works fine when IBurst sucks
