Happy Camper
Hi
I need some advice on setting up a new network solution for about 30 clients. I'm a graphic designer by profession and have been thrown in the deep end here at work as I've been given the task of administering our network for the company. Basically, I'm near to clueless!
The part of the network I want to change is set up with about 30 clients, each with their own desktop pc running windowsxp, connecting to Windows servers running the necessary services needed for their application. I was thinking of perhaps going ThinClient network, all running under Ubuntu Linux. It will need to have Internet Explorer installed under WINE as many of our browser based apps will only run under IE :wtf:
Is this a bad idea? If you are in the know or perhaps could provide a solution or some advice I'd be most appreciative. The main objective is to save money on windows licensing, cut down power consumption (thinclient network don't need hard drives nor gfx cards, less heat means less air con usage etc).
Many thanks for any advice offered.
