NEW CAR ENGINE SENDS SHOCK WAVES THROUGH AUTO INDUSTRY
spf1007
Pretoria
Despite shifting into higher gear within the consumer's green conscience, hybrid vehicles are still tethered to the gas pump via a fuel-thirsty 100-year-old invention: the internal combustion engine.
However, researchers at Michigan State University have built a prototype gasoline engine that requires no transmission, crankshaft, pistons, valves, fuel compression, cooling systems or fluids. Their so-called Wave Disk Generator could greatly improve the efficiency of gas-electric hybrid automobiles and potentially decrease auto emissions up to 90 percent when compared with conventional combustion engines.
The engine has a rotor that's equipped with wave-like channels that trap and mix oxygen and fuel as the rotor spins. These central inlets are blocked off, building pressure within the chamber, causing a shock wave that ignites the compressed air and fuel to transmit energy.
The Wave Disk Generator uses 60 percent of its fuel for propulsion; standard car engines use just 15 percent. As a result, the generator is 3.5 times more fuel efficient than typical combustion engines.
Researchers estimate the new model could shave almost 1,000 pounds off a car's weight currently taken up by conventional engine systems.
Last week, the prototype was presented to the energy division of the Advanced Research Projects Agency, which is backing the Michigan State University Engine Research Laboratory with $2.5 million in funding.
Michigan State's team of engineers hope to have a car-sized 25-kilowatt version of the prototype ready by the end of the year.
6a00d8341bf67c53ef014e874784bb970d-800wi
[video=youtube;uf_-IMgla34]http://www.youtube.com/watch?v=uf_-IMgla34&feature=player_embedded[/video]
Discovery News
I don't know much about cars but this sounds like it could make things simpler to understand :)
I'm not a car expert, but how does this differ from the Winkel engine?
****el. This doesn't drive the wheels, it drives a generator to charge the batteries on a hybrid car.
edit: That censored part should read W-a-n-k-e-l
They must be really eager to get this off the ground....
You mean the W@nkel rotary engine.
The W@nkel rotary engine is less thermodynamically efficient than a piston engine due to the shape of the combustion chamber.
What the W@ankel engine does do is provide a lot of power in a small and lightweight package - it is not very efficient though.
This new invention is still an internal combustion engine - just a more efficient one.
I'm very cautious of the claims of new developments. Often the figures presented are overly optimistic.
Also sometimes there are hidden problems that need to be resolved before the device can be used in real life applications such as wear and longevity issues.
Those problems can often be a nail in the coffin. Examples: The air-powered-car, Moller Skycar and a lot of EV's over the past 50 years.
R&D needs money to survive so they often spout grand ideas and figures to keep their investors happy.
Since when is ****el a banned word?
