BioWolfZA
Hi guys,
I was hoping someone could help me out with an issue i am having.
I recently upgraded my graphics card from a BioStar HD4890 to now a Gigabyte HD7850. I also put in an asus Xonar DG sound card and a new case, the Coolermaster Elite 430.
Everything else that was working fine before has stayed the same:
AMD Athlon X4 640
4GB DDR2800
Raidmax 730W PSU
Asus M4A78 Mobo
LG W2343S-PF 23 inch
The problem i am having, and that only started AFTER the above upgrade, is that when i am gaming (Eg MW3, TF2, Sins of a solar empire etc.) i get these faint horizontal lines across the screen, that make me think of scanning lines on a tv that sort of go up and down the screen. This is obviously very annoying, and is particularly clear in dark areas of games. The first thing i thought was heat, so i made sure that all fans (case, cpu etc) were securely mounted and i monitored the temps while gaming of the GPU and CPU (Which are NOT overclocked). Neither goes over 60 degrees at any time, even after an hour or two of heavy gaming. I even tried increasing fan speed using speedfan but didnt help.
I also thought that it might be screen tearing due to the higher fps. I know what screen tearing is, and in this case the picture is not torn it is still intact while the lines run over it, like seeing through a ghost. I tried enable Vsync but this only appeared to help a little, although it did help slightly, the issue was still there.
So i did a google search and found that many people with the same issue were reporting that it was the monitor cable, especially where it was a VGA cable as i have. Or the VGA to DVI converter. So i got an unused brand new VGA cable and converter but this did not make the slightest difference. I can't test a DVI to DVI cable as my monitor only takes VGA.
Another suggestion was that it was the PSU causing interference. Now the thing about that is that in my new case the PSU is bottom instead of top mounted, so i thought this could be the cause. To test all of this out i put my old graphics card back in and the problem completely dissapeared! If it was interference, surely it would affect the old card as well? Could the new card be more sensitive? I tried unmounting the PSU and moving it closer and further away from the card while running, but the lines stayed constant.
As a last resort, i tried reinstalling drivers (uninstalling, using driver sweeper etc) but no difference.
My reaction to all of this is to return the card, but could i be missing something? I do not want to return the card only to be charged to have it returned to me saying there is nothing wrong with it.
I would really appreciate any insights and opinions!
Thanks in advance!
P.S. Sorry for the essay, i just wanted to make sure that all the details had been provided.
AMD Athlon X4 640
4GB DDR2800
Raidmax 730W PSU
Asus M4A78 Mobo
Thanks in advance!
