New power point costs?
Noob-Noob
Okay,
So im staying in my gran’s old home, now for some or other reason the old people did not believe in an excess amount of power points,
Now im going to star renovating the house in the coming months, and the 1st thing i want to do is install 5 new power points throughout the house (currently have 4), does anybody know what the costs for this wil be round about?, will the technician be able to drill or cute the new lines into the walls for the power lines?, is there a more simple way of doing it?
Does anybody perhaps someone in the Pretoria area they can recommend?
nb, it goes without saying its a brick house :p
Edit
On a side note,
I have 1 plug in the kitchen, 1 plug in my room, 1 plug in my grans old room, and 1 in the living room, in my room alone, im using a amplifier, a computer, a server, a active amplifier, the plasma, 2 phone chargers, a router + a switch, a DVD player and a media player, obviously i cannot connect everything at a time, but i don’t think it can be healthy for all these devices to be on 1 power outlet, connected to a multiple, connected to another multiplug,
When my ex was still staying here, it was her hair dryer and straightener as well.
Besides the fact that i think it can’t be good, it looks absolutely horrible, the plug is in the one side of the room, and most stuff on the other side, so i had to put in an extension cable running around the room.
The kitchen i have a kettle, microware, toaster, snack witch machine, snack witch presser, slow cooker, and losts of other stuff, (don’t forget the fridge), so each time i have to unplug the fridge if i want to make coffee....i did install a build in multiplug on that outlet, so luckily the fridge can run permanently now.... i honestly cannot see how they managed to life like this....
ToxicBunny
Oi! Leave me out of this...
You will have a massive mess while its done, but its entirely doable.
it will probably require a small modification to your DB Board to add new circuits, and then chasing the walls, putting in conduit, replastering and repainting.
To sum it all up, it won't be cheap.
Noob-Noob
I don’t expect it to be cheap, nothing is affordable these days :p
But im looking into renovating the whole house in any case, im just scared you will be able to see where they had to cut the walls for the power lines, normally the replastering looks like crap, but i honestly cannot live any longer with only 4 plugs in the house.
Do you think it will be more than ± R6000?
im trying to work out what everything will cost, then i can go and borrow the money once off and fix everything one go, bit its difficult budging if you have no idea what most things will cost,
i have worked out a new floor (laminated flooring) wil be R11000
Bathroom = ± R15000
Paint = R3000
Dim lights = No idea
Power points = no idea
ToxicBunny
Cost is the massive issue.. i wouldn't be able to give you an idea on that unfortunately.
If you just repaint that small section, then yes you will be able to notice.. repainting the whole wall should hide it though.
Noob-Noob
Thanks!!
akescpt
im wanting to automate my garage door and they are tuning me that they gonna charge me R500 just to take the powerpoint closer to the motor. im wondering if i can do it before they get there and pay cheaper.
Noob-Noob
Well if they charge me R500 per powerpoint i guess it won’t be that bad, if it includes the sement and the plastering, the wire and the connection to the powerboard, I’ll even pay R1000 per point as its allot of work, but higher than this it’s going to start to become a rip-off
MDE
When we reno'd our kitchen we were charged R650 for a double and R450 for a single which included the chasing and R1000 for two new 15Amp breakers. This excluded the replastering and painting which the builder did.
Hope it helps.
Noob-Noob
Hope it helps.
Most probably i wont have a builder, the floors and the build in cupboards i will be doing myself, i will have a tiler for the bathroom though,
R650 is good, but for me getting a separate builder just for that little plastering seems stupid, will maybe get one of those guys sitting infront on builders, they cant be that expensive :p
