Newbie with small question
Wally
Howdi All
Very informative forum you have going here. ;)
I have a quick question. I know as fact that depending on the type of account (prolog etc) you can have up to 4 concurrent connections with one user/pass.....
My question is: Say for example I have a 384 adsl at home and 512 at the office. Can I use the username/password (prolog+) that I obtained from the 512 line concurrent on the 384 line? Or can you only use concurrent connections on the SAME linespeeds??
cool
If you can use concurrent connections on your account (many do not allow that) most likely it doesn't matter on what line speed you going to use it ... so I assume you can use it, why not try it and see.
