Nexus 6P Or S6 Edge Plus?
StatikSA
South Africa
So recently got my S6 Edge Plus and not liking it that much was deciding to return it for a 6P any suggestions? (I am aware of some features i might lose)
Thanks a lot.
So basically then you're unhappy with the Edge+ because you feel there's something better out there?
Here's the thing...Edge+ has Samsung's Exynos chip which they made specifically because the Snapdragon 810 the 6P is using is known to overheat.
Yes I've heard, but not from the 6P, which appears to handle the chip quite well. Check out some reviews, I think the 6P is a great phone.
