Hi all.
My Nikon camera just decided to die on me and don't read any kind of memory card.
I used it in January still when we went to Kariba and all was good.
Came back and downloaded all pics.
When i wanted to use it the other day it just won't take any photos anymore.
Everytime when i switch it on it says:
"This memory card cannot be used. Card may be damaged. Insert another card"
I've googled this and a few places it states to do a factory reset by pressing the two green dot buttons.:wtf:
Did that with no luck.
Also they said some of the contacts inside the card slot might be bent or damaged.
Looked in there with a light and all seems in place and nothing damaged or bended.
I've change with numerous cards and new ones straight out of packet and all cards is working fine by reading and writing through the computer and even re-formatted them and still no luck.
If you do have any advise or suggestions out there to get my camera up and running, i would really appreciate it.
