I was given a Nikon D70 camera as a present recently. The only problem with it is that it doesn't have a cable that goes between the charger/transformer and the power source. What is this cable called and where can I buy one?
Is it not one of those standard 'figure 8' cables? Any retail store should have one or else try builders warehouse
It should. If not you can always trim it.No. It's almost like that except the bottom part of the 8 is square not rounded. Like this.![]()
It might still use that same cable though.
