Did you not like his myfacebook update?Hacked account? I don't think I've ever seen you write a sentence.
The browser itself will continue to be supported for the lifecycle of the Windows version on which it is installed until June 15, 2022.
Edge?Who the hell still used Internet Explorer instead of Edge?
I thought they killed it years ago already.
Edge?![]()
Guys seems there will be no update for Microsoft explorer after 15th of June 2022
Ms advise to shif to Microsoft edge
Any update cause I have little information on that, It is just hearssay
Our SSL VPN needs Java, and unfortunately IE is pretty much one of the only browsers that still supports it. Tried different plugins and whatnot, and closest is Firefox, but the plugin is no longer supported. The platform runs fine on Secret Server, but I’m still trialling it and the cutover won’t be anytime soon, so come 15 June there are going to be a LOT of people who are going to be unable to connect.
Edge is Chrome. What do you use?
Chrome... and Opera.Edge is Chrome. What do you use?
We still need to support IE in our software. Apparently there are some corporate customers who still use only IE for some reason or other.Who the hell still used Internet Explorer instead of Edge?
I'm using various browsers, DuckDuckGo, Firefox and Chrome. Edge uses Chromium. It's like Chrome but it will never be Chrome.Edge is Chrome. What do you use?
It's because they are using outdated frameworks and don't want to spend money on development to update to be compatible with newer browsers. Probably Flash-based stuff.We still need to support IE in our software. Apparently there are some corporate customers who still use only IE for some reason or other.
