Hi all,
Can anyone recommend a good pair of noise cancelling earphones? I work from home and we live right next to an extremely busy road which is driving me crazy and giving me headaches every day from the constant traffic. It quite honestly sounds like the road is running through the middle of our house. Fortunately we're only living here for another year, but in the mean time I need to find a solution.
I believe there's all sorts of options such as noise cancelling, noise isolating etc. Basically im specifically looking for headphones that when used, simply cut out all (or most) external noise.
I dont really care if they're good quality in terms of playing music because im actually just planning to wear them with no music or anything playing. I simply want them to make the world quiet!
Does it matter much if you get the ones that cover your ears completely or not? I see you get some which dont cover your ears completely but seem to still do the trick,...presumably by active noise cancelling.
Any suggestions? Experiences?
