"Noise Margin" and "Line Attenuation" Help
jeppe777
Durban
Been having some problems with my adsl line. frequent disconnects, modem looses snyc. Please Have a look at my Stats, are these ok or bad?:confused:
Mega 100WR
Connection Status Connected
Us Rate (Kbps) 512
Ds Rate (Kbps) 4096
US Margin 13
DS Margin 11
Trained Modulation ADSL_G.dmt
LOS Errors 0
DS Line Attenuation 23
US Line Attenuation 12
Peak Cell Rate 1207 cells per sec
CRC Rx Fast 982
CRC Tx Fast 47
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
your Noise Margin looks okay....mine is US 12 and DS 31! but your Attenuation DS looks a little high but not so that that should make your line drop....(anyone els has a comment, i am kinda a noob but my bro works for telkom so i have some kinda insight)
so long as the Attenuation dont go above 31db...
Path Mode mite swith few time between "fast path" and "Interleaved Path" which mite make the line loose sync.
try setting your routers ADSL standards to automatically negotiate with remote DSLAM on trained Modulation... i have a 4meg line a found that adsl2+ works best for me... but i am a novice hehe
Also, look out for flourescent lights, CFL bulbs, transformers, exposed wiring etc. near your telephone lines inside your house and on the outside wall. These items generate AM noise on the line which can cause frequent disconnections.
My attenuation is 46.0db (4mb) and I never get line drops...
I would say your problem is that you have too little DS noise. But from what I understand Telkom can easily fix this? Your attenuation indicates that you are reasonably close to the exchange so that shouldn't be the problem, but I think the noise should be about 15+
