Nokia 5130 firmware question
Just_Ice
RSA
I can see from comments on nokia forums and that, that the latest firmware version is 6.94. Yet if I go check the latest version for my phone it still shows as 6.65 and so I cant update.
What gives?
An update is in order with all the freezes and resets that I experience on occasion
Take it to your local Nokia care store and they will do it for you under warranty as long as the phone is not liquid damaged or physically damaged and is under 2 years old. 031-5613306
Thanks, Ill try that! Even though it was bought from a cell c outlet but I use my vodacom sim?
