Nokia N97 firmware
benitok
I see on the web they talk about the N97 firmware 2.0 which is coming out soon. Where on the N97 do you check the firmware version that you have?
I can only see software version & custom version.
On the "dial" screen, type / press in the following --> *#0000#
And yeh, the software/custom version is the firmware version...
Cheers
Don
Cheers
Don
Thanks Don, my version is 12.0.026, but I see they are talking about firmware version 2 coming out in October, am I missing something?
Nope, not missing anything, but, the firmware update has been delayed, no-one knows when they going to start the rollout...
Cheers
Don
hmmm, mine says 12.0.024
That just how nokia works. The first number one means version 1. The second number means the release 2. and the 24 at the end just the Build number. The 0 between the two points I'm not to sure off but could mean a build specific update number.
This in normal language you have Version 1.2 [Build 24]
Firmware 2 would like look something like: 20.0.0XX
That just how nokia works. The first number one means version 1. The second number means the release 2. and the 24 at the end just the Build number. The 2 between the two points I'm not to sure off but could mean a build specific update number.
Thanks, now that makes more sense.
