Nokia USB phone charger?
feo
Pretoria, South Africa
Hi
Is there such a thing? I got a 6230i and would love it if I could charge my phone from a USB port. If iPods can charge this way then why not phones?
phones can, especially nokias.
your usb is 5v at 500ma, this is enough to charge a nokia phone (the batteries int he phoen are typically 3.2volt)
all you need is a cable, connecting the usb + and - to the correct pins on the phone. When bored, snip the wires off a charger, snip the wires off a usb extension cable and solder away.
If you can connect your phone via usb with some software,it generally acts as a charger when software is installed.
