Noob in a pickle, may I ask for some help please
Paul2504
I need to add a 3rd Ubuntu PC to an existing share. I am stuck and need some help please
Existing Share from where?
How did you add the other two? It should be the exact same.
I had help previously, now emigrated .... he did ... not me.
He did something clever with samba
If I understand correctly you want to access a shared drive from Ubuntu?
If you have samba installed you should be able to mount as such:
Code:
smbclient -U user -L 192.168.1.5 (replace IP with your share IP).
Enter Samba\user's password.
Code:
sudo mkdir mnt/yourhsarename
mount -t cifs -o username=user //192.168.1.5/sharefolder mnt/yoursharename
To persistently mount you will have to modify the fstab
Code:
//192.168.1.5/sharefolder /mnt/yoursharename cifs username=user,password=password,_netdev 0 0
Alternatively, you can create a credentials file to store the login credentials.
