not AGAIN!
Yep times like this, not even FreeProxy will work, well.. if the whole of international is down. Only our Local LowPing solution will be usable to gain international gaming access.
ps. I just checked, still 100 odd users connected to FreeProxy, I doubt its a national international down problem, seems like selective areas or you are capped ;-)
Could I ask what modem you got?
I've just ordered a new router again today to test, though certain sites have mentioned it gets a bit hot. My current modem never gets above ambiant and wouldn't want to know I've paid through my teeth to have a over heating problem?
overheating prob? or a heater prob? :_)
dlink routers allways so damn stable, Ive used all of the dlink range so far and none of them even get above room temp, and so stable.
Blah you know what I meant! My current modem (as you know) has been as stable as hell for ages.
I've got the ADW-4300 on its way tonight.. but not to happy with the reports of it getting too hot. Which I think is why the ADW-4301/2 were dropped to 12 V.. but you either cant get them, or they are on a 6 week waiting list
Just wanted to make sure it was not the same router MM has?
