Note 5 or S6 Edge
Hazelbag
Kyalami
Hi
Between the two devices which would you suggest? I spoke to vodacom hoping to get a dual sim but they don't stock dual sim devices they said.
So which one would you suggest over the two? I currently have a Z3.
I'd go for the Note 5. Looks like a great phone if you can handle the lack of a memory card slot or removable battery (seem you did with the Z3)... S6 Edge is great too if you want a smaller phone
Yeah the Z3 is great, the internal memory sucks but great device. But the note 5 does not seem much bigger than the z3 and it will be used for work mostly.
Note.
The S series is hond *** I have it I will know
G4.
removable battery.
SD slot.
Will be the first on Marshmallow.
no Samsung bloatware.
no Sony lies about how durable it is.
did I mention the leather back?
I would say go with the Note 5. Really loving mine so far.
Hi
The S7 and S7 edge is launching next month.Bigger battery,water resistant and the micro sd is returning.Google is also working with Samsung this time.Touchwiz will be lighter and more nexus like.
Rather wait.
http://venturebeat.com/2016/01/04/s...icrosd-water-resistance-and-larger-batteries/
http://www.sammobile.com/2016/01/05...rosd-slot-pricing-and-screen-sizes-confirmed/
http://bgr.com/2016/01/05/galaxy-s7-specs-larger-battery/
