Office 2007 - Help lol
NVM, found it, it's under 'Insert' then click on shapes, select one, like a line, drop it on the sheet, and then it will open a 'Format' menu on the ribbon. If you click a cell the menu hides so to get it back you must click on one of the shapes you dropped on the sheet.
