kwaggawerner
OK, Here I go:
I have Wimax, for those of you who don't know how it works, think of wireless ADSL... it does the same thing... I connect to the internet via a PPPOE account.
Now, I have an AP connected to the WIMAX device... One WLAN client connects directly to the net via Windows XP PPP Client. For client 2, that's me, I also connect to the MAIN AP via WLAN, but from the Client AP I run cable to a wlan router, so the link from the main ap/client2 connects to the WAN port of the wlan router... this router then dials another PPPOE, and distributes it via WLAN again, and then on this 2nd AP/router, 3 clients connect.
I know, laborious, but at the time this is what worked, let me explain, I tried IPCOP, I tried Kerio, nothing worked, because Client 1 needs international internet, client 2 needs a PPP availability, because client 2 needs international at times, and sometimes local, but the second AP must always provide international to clients 3,4,5. And the second AP connects to the CPE of client 2.
Now here is my question, how can I have one router/server/firewall, dial an intl connection, have clients 1,3,4,5 on it, but still allow client 2 to dial his own connections? I know the simple answer is ppp-relay/passthrough, but it's not working, since the MAIN AP is DD-WRT (Which does not support pppoe-relay) and then there is the problem with distance, thats why there is a second AP for clients 2,3,4,5.
Any ideas, of making this setup a bit more streamlined? Reason being, I cannot switch local/intl without forcing client 3,4,5 also on whatever connection I choose - currently client 2 is also connected to AP2.
If I throw in a server (IPCOP/Kerio) in the link, say, between the wimax and the MAIN AP, It can only dial one connection, and should I open a pppoe passthrough port, and dial ppp2, then ppp1 stops sending/receiving data... although it does not disconnect.
Ideally, it would be great if kerio (example) can dial a connection (ppp1), have client 1 go through ppp1, then allow AP2 to dial PPP2(for clients 3,4,5), and allow client 2 to also dial its own connection or have client 1, 2 and AP2 dial their own connections.
"Taking a simple network, and turning it into something the OSI-model doesnt know how to handle, or, Telkom's infrastructure can't handle - or simply put, I'm an idiot"
