Old WUG kit (directional antenna system)
repitah
---- CLOSED ----
I'm looking for an old WUG kit (MikroTIK or similar) to use as a WiFi bridge between my house and the complex guard hut (primarily for the cameras DVR to get time sync and maybe remote viewing/download). Primarily I want the directional 2.4Ghz antenna (covers the ~50m to my AP in the roof)
I can buy a cheap TP-Link directional AP off Amazon, which should also do the trick (reloaded to OpenWRT; disable reset button so people don't get clever with it), but if anyone has an old kit laying around causing clutter, I'll pay for the locker-to-locker.
Eventually went with 2xCPE210's and works a charm (roughly 20Mbps through a thick tree). Didn't reload with OpenWRT (I did, but reverted as the official firmware met my needs and did VLAN per SSID). DVR gets time sync (couldn't be bothered to airgun the old battery off) and found an old notebook to do the IE ActiveX plugin to download footage if needed.
