Old ZA water mains key
CntrlAltDel
Hi there,
Does anyone know which water mains key is used for the below stop tap? For the last 15 years every time I've needed to turn it off I've needed to use 2 shifting spanners at great cost to the skin on my knuckles.
My knuckles will be grateful for your assistance.
Two shifting spanners?
I use a simple pair of fat nosed pliers on that.
But also why don’t you have your own stop tap on the other side of the meter? You aren’t actually supposed to use that one.
That doesn't work. The angle is too awkward and what you're not seeing the picture is the gravel's proximity to the stop tap.
I used waterpump pliers at my place in Joburg. The mains stop was under the paving in that stupid metal meter cover.
Or just ask them to replace the meter to one of those bulky plastic ones. Ours has a easy accessible flat tap to close the water at the meter.
Make your own, or put a tap just after it. I moved my stop tap above the soil, so easy to operate now
