I have resolved some of the problems - flat spot - on my Corsa, but it seems I have created new ones.
I have replaced: - Ignition coil pack, the idle valve sensor, the hose from the airfilter with a new sensor. the fuel filter.
I have checked the timing, and it seems ok, with the tappets on number 1 cylinder rocking, and the piston at TDC.
The spark plugs are no longer wet, and has no carbon deposits. How ever it burns completely black. I use BPR5EY plugs, with a .75mm gap.
My new problem now is that the Corsa is smothering when I want to accelerate with power loss on inclines. It is also exceptionally heavy on fuel - approx 6km / liter! I have checked for fuel leaks at the filter, with the engine running, no leaks.
Please help?
Please help?
