ODTech
So my corsa rear left brake is not working. It makes a squealing/grinding noise and i am able to turn the wheel with the handbrake on.
I tried to open it to see whats going on but i cant get the drum to budge. Google shows you have to remove the axle nut cover and then the axle nut on the corsa c car but i cant apply those steps here because it doesnt look the same. I suspect the utility has the sealed hub/bearing the back..?
I removed the wheels nuts, wheel and a small screw in the front side of the drum. Do i just keep pulling/prying at the drum until it comes off?
