I have an Opel Meriva 2005 with both orginal keys. After all these years of use the casing on both remotes has holes in and the one remote actually broke (the button and some small parts came loose).
Phoned 2 dealers for a replacement of the remotes only. One quote me R1400 (excl) and the other (R1700 excl). One also quoted (R500) for the casing (measures about 4cm x 3cm x 1cm) only!
The reason for the pricing according to them is that the remote must be coded...
Is there any other place than the dealers where the remote can be bought and coded?
Or can I use a generic remote and have it coded for the car?
Or any other option?
I stay in KZN.
Thanks in advance.
I stay in KZN.
Thanks in advance.
