OpenOffice spreadsheet help
Boodles
I have various names in the first column, and the list is getting longer.
How can i have the names sorted in Alphabetical order? Whats the function i need to put in so it automatically does this each time i add a new name?
Just remember, my nic is actually begins with a hidden 'z' ;)
Seriously, (did i say actaully say that) can anyone help?
And no its not people's names (nor is it nics)
I couldnt be bothered searching openoffice forums for 2 hours with a lack-lustre latency crappy interent nonsense that i have to put up with every day.
Boodles I don't know of a function but will it be to hard to do a "Sort Ascending" every time you enter new data?
Or am I understanding your question incorrectly and your searching for the "Sort Ascending" button?
Regards,
Its kinda like this
ZX 4 5 6 7 8 50
er 3 5 6 7 8 90
rh 5 6 7 8 8 50
ty 5 6 7 7 8 54
Yes, look i can sort after adding, but first i need to sort, and thats a pain.
I've just found the sort-ascending under the data tab.
I'll play with that for awhile.
Thanks.
Thanks, D--B, that did the trick.
No problem Boodles, I uploaded a picture to show you where it is in the tool bar.
You will also see I selected all the cells, because it will only sort the selected cells. So if you do not select all the needed cells it will scramble you data around.
Regards,
ps: it's d dash underscore dash b ;)
