Amara Solutions
Hi Everyone
I am starting this thread due to a lack of knowledge on the subject so let me explain my situation. This is how my network is configured:
OpenServ Fibre Router (Nokia)-> Cool Ideas ISP (PPPOE) -> Unify USG Router -> Mirkotik 24 Port Cloud Switch (Configured as just a switch)->
LAN 1 (VPN1) 192.168.1.x
LAN 1 (VPN2) 192.168.10.x
LAN 1 (VPN3) 192.168.100.x
Last night I was trying to setup a new Mikrotik. I normally connect the unit to my existing network using a specific port on the existing Mikrotik and connect to the Mac address with Winbox for configuration. By absolute chance I accidentally selected the option to connect to the IP address and suddenly I got the notification that I could not connect due to incorrect username/password. Knowing that this was not possible as the 192.168.88.x range is not configured on my network I decided to ping the IP address and got a reply that should not be possible.
Running a trace route I could see that the IP address was located in front of my USG router outside my network.
So I disconnected all my equipment after the OpenServ Router and connected it directly to my laptop. From here I could ping the following addresses:
192.168.10.1 , 4 ,6 , 5
192.168.11.1 ,5, 6
192.168.88.1
My question is then are these setups on the OpenServ router and how is this possible (Routing/Setup issue)? How do I get this fixed?
I can clearly see from the tracert that 192.168.88.1 is located behind 192.168.11.6 and that it is someone else's Mikrotik/Equipment the same goes for 192.168.10.x. In the mean time I have added a Firewall rule on my USG to block all incoming/outgoing WAN communication to those IP ranges but would need to update these rules continuously if more addresses crop up and that is both not ideal and also not secure.
192.168.11.1 ,5, 6
192.168.88.1
