Opinions required
Nefertiti
JHB
So my motherboard packed up in the last week :mad: and it was recommended that I rather just upgrade to the new i5 or i7 setup. (I had a Q9450 and 775? motherboard before that).
So options I have is.
  • buy an ssd for my notebook to tie me over until the upgrade
  • just upgrade already
What is making me hesitant in just buying anything right now...
The newer SSD's are coming out, so I am hoping the vertex 2 or g.skill phoenix would come down in price. My notebook is a year old, so adding the newest ssd's to it would be a waste. Should I wait maybe? or is waiting for the price to come down just wishful thinking?
If I go for the full upgrade, I would like to do it properly. There is the new LGA2011? processors coming out, that would support 6 cores and up. The high end processors tend to be quite pricey but rumour has it that the price might not be so bad. Should I wait? Yea, I know technology always changes, but I want to get something that would last me at least 3 years. So it needs the latest SATA III, usb 3 and anything else coming along now and in good quantities. 2 of the latest SATA ports wont cut it if I want to do raid.
I wouldnt worry about the specs being an overkill in my case. I make good use of the resources I got :D.
if you were in my position, what would you do? would you wait or which option would you go for?
Replace the motherboard and get the ssd
Problem solved. I would rather have a q9450 with an ssd than a i5 or i7 with a 7200rpm drive. What is the machine going to be doing?
Do you still get motherboards supporting the q9450? I got feedback that the motherboard would cost me thousands to replace. But then I did have extra requirements like either onboard video or to run dual video cards (not in sli mode though and well I am willing to forfet the video card options). I do coding mostly (sometimes in virtuals). So ram and harddrive speed more important for me.
You won't get native USB3 till Bulldozer comes out. I say wait a month to see what Bulldozer does. Save up. You'll be able to get yourself a juicy 8core. Also with AMD you know they don't release a new socket every six months.
I'd prefer Intel, however I'll keep my mind open and check some stats when it comes out.
Well rectron has these two MB's on their price list so any dealer buying from them might be able to assist...
GIGABYTE® G41M-COMBO: G41 & ICH7 Chipset - Socket LGA775, 1333MHz FSB - Supports: Celeron, Pentium Dual Core & Core 2 Series (price incl: +- R520)
GIGABYTE® G41MT-S2P: G41 & ICH7 Chipset - Socket LGA775, 1333MHz FSB - Supports: Celeron, Pentium Dual Core & Core 2 Series (price incl: +- R455)
So i do not know where the thousands come from as you were told...
Remember these are prices from the initial supplier so the dealer will most propably add another 20% or so to the price...
I think they were looking at replacing the motherboard with the exact same specs as what I had, and it could have included memory upgrade as well.
Im looking at the motherboards you suggested now... looks promising.
