rubber_otter
- May 25, 2009
The Oppo A72 is an affordable smartphone with modern looks and fine specifications. For example, it has a large bezel-less screen, a large battery and 48MP quad camera. But is it also a good choice? Time to find out.
Sharp screen with eye care mode
Those who still want a skilled phone but do not want to pay the first prize for it, Oppo released the A72. At least that's how it seems, because on paper it has everything you can expect from a modern smartphone. A large 6.5 inch sharp screen for example. It's almost everywhere against the edge with only a small hole in the top left corner in front of the selfie camera. In order to be able to look at the screen for a long time as well, Oppo has equipped the A72 with a special eye care mode. This reduces the amount of blue light depending on the amount of ambient light. Blue light in particular causes tired eyes. To save your eyes even more, there is even a Dark Mode available. Friendly for your eyes and the battery. With a maximum brightness of 480 nits, the panel alone is not very bright. Although that's only annoying outdoors in sunlight.
The focus on the cameras
On the beautiful light reflecting back we find a so called AI Quad Camera. This is a camera system consisting of four lenses that takes the most beautiful pictures with the help of artificial intelligence. The main sensor measures 48MP and shoots sharp and detailed shots. The f/1.7 lens ensures that you can do this even in the dark without having to flash. There is also an ultra-wide-angle camera with 119° lens for wide shots of landscapes, for example. The other 2 cameras use the A72 to take beautiful portrait photos. For example, one lens recognizes depth while the other only captures shots in black and white. Because the latter only has to deal with 2 colours, he shoots sharper shots. Ideal for portrait photography, possibly with an out-of-focus background. A pity is that the cameras are a bit protruding.
Main Oppo A72 specifications
Spacious 6.5-inch Neo-Display with sharp 1080p resolution and Eye Care
48MP AI Quad Camera with 4K video, AI Beautification, Ultra-wide-angle and 2 portrait lenses
Snapdragon 665 processor with 4 GB RAM memory
Extra-large 5000 mAh battery with 18W fast charging and Power Share
Dual Stereo Speakers with Dirac 2.0-sound effects
16MP selfie camera sits in punch-hole
Royal 128GB of storage memory
Large battery can even power others
The Oppo A72 is equipped with a large battery of no less than 5000 mAh. You will not find them much bigger at the moment. There is support for fast charging, but this can be done with up to 18 Watt, so full charging still takes some time. Another handy feature of its large battery is that it can be used to charge other devices. There is also plenty of storage memory. At 128 GB, it is remarkably large in this price category. Oppo chooses to power the A72 with a Snapdragon 665 processor. This is a so-called mid-range chipset that is often sufficient for average use. However, you won't win races with it. Furthermore, it is good to mention that there are stereo speakers present. Ideal for listening to music.
Color OS 7.1
I am still in two minds about Color OS 7.1. Being a first time user, it took some getting used to. But 2 days later, I was operating this phone like one would any android device. Some nice touches is that Oppo has included options to chance various display items. Like changing your Icon shape and size, something only ever achievable by third party software.
With a recommended retail price of R6’999, it is a bit on the expensive side for a mid-tier device. But the 48MP camera and 5000mAh battery sure make up for that.
Color OS 7.1
