An exciting opportunity is available for IT Technical Specialist to join the the Retail Systems Operations area of TFG Infotec, focusing on Support of Distribution systems. If you enjoy the challenge of technical troubleshooting[/B], are committed to customer service and have excellent communication and problem solving as well as coding skills, you should consider applying for this position.
Key performance areas:
• Performing analytical assessments and investigations - either to code, or business processes
• Ensuring that calls are resolved in accordance with the requirements of the relevant SLA
• Identifying and/or resolving root causes for issues
Requirements:
• A relevant tertiary qualification
A min. of 3-4years relevant working experience
• Proficiency in Oracle Database version 9 or higher
• Experience in PL/SQL, SQL Plus Programming, and Unix Shell scripting would be beneficial
• Proven working experience in the System Development Life Cycle (coding, testing and implementation)
• Experience in Retail / Distribution Centre processes and distribution / logistics
• Experience in end to end system testing (UAT, integration and volume testing)
• Familiar with Warehouse Management Systems and the implementation thereof
• Experience with Manhattan WMS would be beneficial
• Excellent communication skills (both written and verbal)
• Excellent listening, probing and documentation skills
• Professionalism
• To be a self starter with the ability to work independently
• To be a team player
• To be able to pay close attention to detail
• To be able to work under pressure
• Good planning and time management skills
• To be reliable
If you are keen to apply, then please visit our careers portal-www.tfglimited.co.za
Preference will be given, but not limited to, candidates from designated groups in terms of the Employment Equity Act.
Requirements:
• Professionalism
• To be reliable
