You should be able to connect to the "boxie thing" post a photo of it. Probably a multiswitch with different types of satellite outputsIs it possible to have both of these without rewiring the dish? I currently have a quad lnb and a boxie thing by the TV with lots of free ports.
Will post a pic... Does the same satellite direction work though? It read it may point differently?You should be able to connect to the "boxie thing" post a photo of it. Probably a multiswitch with different types of satellite outputs
OVHD can use the same satellite as DSTV, so will work fine.Will post a pic... Does the same satellite direction work though? It read it may point differently?
So it used to be different? Does anyone have both running?It's only the same satellite now.. had to move mine back to DStv position
