Hi guys,
I would like some advise on what spec solar panels to connect to my inverter. I would like to DIY my pool pump from solar. I don't want to use batteries. Only solar. Inverter will be connected to the pool pump DB for AC supply as 2nd alternative.
Pump spec:
Speck 1.1kW
Operating Watts: 1085w (Tested)
Start-up watts: 1630w (Tested)
Proposed Inverter: Growatt 3000w. Max PV array 1500w. Max open circuit voltage: 102VDC. MPPT range@operating voltage: 30-80 VDC.
https://www.solarwaysuppliers.co.za/wp-content/uploads/2014/01/GROWATT-PDF-NEW.pdf
Questions:
Thanks in advance
Delwin
Pump spec:
Speck 1.1kW
Questions:
- I'm thinking of getting 3 x 400 watt panels. Is that fine? What do I need to look out for?
- Can the inverter operate without batteries connected?
- If the power generated from the panels doesn't meet the full pump load. Can the balance be taken from the grid?
- I assume the motor start-up can be powered by AC and then switch to solar for operating power?
Thanks in advance
Delwin
