Pastel Partner in Head Quarters
scy
I want to connect 6 stores in different locations running Pastel Partner so that they can be monitored from the headquarters. I must be to view reports and inventory from the head quarters.
There will be store servers at the 6 stores and the main server at the head quarters.
Has anyone done this?
How did they go about it?
Please advice.
Regards,
Please advice.
Regards,
Rather look into Pastel Evolution Multi Branch system.
https://www.pastel.co.za/Downloads/Add-On-Modules/2013/EvolutionWhitePaper.pdf
Thanx alot, will look at.
Given that we already have licenses for Partner. What would be another solution?
I dont think it will be easy.
I would think every store as a different user with unique set of GL accounts. You can add multiple warehouses in partner but I think you have to pay for this module separately. Will have to do warehouse transfers for stock movements from head office to stores.
But i think it will complicate things when you have a server instore with many users and then have another server at head office. You probably will have to go Evolution for this.
If you have 7 instances of Pastel Partner being 7 servers and licenses there is no way to amalgamate the data. They have to draw reports and email or you RDP to each instance and do it yourself. Yes you can have multiple warehouses but that means each of the 6 stores must RDP to use the system.
If there is a way to automate pulling all data in to a central reporting system I am not aware of it.
I've also never seen that being done. Can't the reports be pulled from the pervasive side?
Maybe look at some inter entity solutions.
