Pastel UNC help: Subnet.
dd1313
Hi Guys
Seeing that Pastel requires a UNC path to connect to it's server, is there anyway to connect to the
server if the IP address of the client is on a different subnet ?
eg:
client IP : 192.168.2.10
Server IP : 192.168.3.100
DD
DNS. I assume you have routing between those subnets?
Haha ja routing better be in place as well.
If DNS not working add the server name and IP in the hosts file on the client pc and should then work fine
