PAT and port Problems - pls help
Shmer
I need some help regarding using any download software. I have a marconi ADSL router, and have tried everything. I have tried using WinMX, KaZaA lite, eMule. I have tried using port 80, 21, 1213, 6699 and 6257. My PAT parameters on my modem are as follows:
No., Protocol, Interface Name, Port, Server IP Adress, Server Port
2 TCP LAN Klite 1213 192.168.10.1 1213
3 TCP LAN WinMX 6699 192.168.10.1 6699
4 UDP LAN WinMX2 6257 192.168.10.1 6257
I still get no connection with UDP or TCP with WinMX and KLite, and 1 kb/s transfer with eMule. eMule and all others I have configured to use all of the above mentioned ports, each on their own. No luck.
Can someone perhaps help me? Should I configure NAT as well? I don't really have much knowledge on these issues, and the user manual supplied with the product is absolutely useless.
