Hey all,
Hoping someone can provide some advice on the below problem:
So the last 2 days my PC doesn't want to start properly. When I turn it on (after being in a state of "sleep") the fan goes full speed and then after about 5 seconds it seems to reset (sounds like it turns off for half a second as the fans slow and the little light on the motherboard blinks out), and then it tries to boot up again. This just keeps repeating.
Yesterday when it happened, I turned everything off, and when trying again, it worked fine. This morning though, even after repeated unplugging and leaving it off for a while, it just wouldn't boot fully. I tried booting without RAM, but made no difference. Eventually after I went and did other things, I came back and replaced the power cable, and then it did boot up. Once booted, it's perfectly fine. I just have a feeling it's a bigger issue than just the power cable, and I'm going to have the same issue tomorrow morning.
Is this likely a power supply failing, or a motherboard issue? The PC is nearing 2 years old after being bought from Wootware in March 2017. If it is power supply or motherboard, would it be covered by any warranty? If not, what else could it be, and what can I try the next time it happens?
Any help is appreciated!
PC Specs:
Gigabyte GA-B250M-D3H DDR4 LGA1151 B250 Kaby Lake Micro-ATX Desktop Motherboard
Intel i7-7700K 4.2 GHz Quad Core Unlocked 14nm Kaby Lake Socket LGA1151 Desktop CPU - Cooler Not Included
FSP Hyper S 600W 80 Plus Certified Desktop Power Supply
G.Skill F4-2400C15D-16GVS Ripjaws 16GB (2x8GB) DDR4 2400MHz CL15 1.20V Desktop Memory
Samsung MZ-75E250BW 850 EVO 250GB SATA6Gb/s 3D V-NAND 2.5" Solid State Drive
PC Specs:
