pc not coming on but front led is, help!!
The_Pumpkin_King
Jedi Master
Gliese 581 d
ok so i got the silver ezcool box from matrix today, the one with the big fan on the side, i transfered everything as is.
now when i put the power cable in the front red led comes on and the screens light comes on but the wont start when i push the power button :(
help!
Does any of the lights on the motherboard come on? Check for any connections that you might have missed, or maybe a short circuit. Did you put the spacers between the motherboard and the chassis?
the green light on the motherboard flashes when i put the power cable in, other than that nothing, spacer is there, i think its with the 3 cables that come from the front panel, power sw, reset sw and hdd led
