Hi y'all.
I need some advice.
The other day I did a clean install of Windows 10 on my SSD and also added another HHD to my rig.
Now all of a sudden my PC would randomly restart. The fans and everything would stay on - but the PC would reboot. Sometimes multiple times in a row.
There is no pattern though. Sometimes it is during gaming and other times its during normal web browsing. Windows event viewer doesnt give me much to go on - apart from saying that the PC wasn't shut down properly.
I have reinstalled all drivers and done every malware scan known to man.
Several Memtest86 passes found no errors.
Temps look good.
I checked all slots,cables and everything looks ok.
Specs:
Win 10 Pro
I5 3570k & Aftermarket air cooler
GTX 1070
24 Gb DDR3 Ram at 1600mhz
1 Tb SSD
250 Gb SSB
5 Tb HHD over 3 drives
No optical drive
620 80 Bronze+ PSU
6 case fans
Everything running stock speeds
Something is dying, im sure. My first thought would be the PSU - but can it be seeing as my PC restarts even when sitting idle ?
Any ideas ?
I need some advice.
Temps look good.
Specs:
Win 10 Pro
GTX 1070
1 Tb SSD
250 Gb SSB
No optical drive
620 80 Bronze+ PSU
6 case fans
Any ideas ?
