PCI-e Gigabit LAN CARD?
CeeBee
Pta mostly
One of our users needs a 10/100/1000 LAN card for his pc.
He just got a new Dell Vostro 200 desktop, but the friggin thing doesn't have gigabit onboard LAN, ONLY 100Mbps.
So only option is to get a PCI card... but, the mobo (Foxconn G33-M02) has only got 2 PCI slots. One is used for a special card they use to connect some UV camera (to take snapshots of gene/DNA) and the other PCI slot I used for a serial port (no onboard serial port on new mobos).
So I figured, perhaps there are headers on the mobo to connect just a serial port, then I can use the PCI port for gigabit LAN card.
But, alas... no serial/com port headers on mobo.
So the only open slots left is the PCI-e slots... are there Gigabit LAN cards for PCI-e slot available locally?
On google I found a few, but sheesh, they cost almost as much as the pc? I dont need such a fancy LAN card....
Any ideas... suppliers?
I guess I can use a USB->Serial adapter, to free up a PCI slot for LAN card... but since the serial connection, for a logger is used all the time, I prefer PCI flavour.
hehehe... yup this looks like it would do.
damn, google didn't thow this out in a search... perhaps my wording just sucked
Yeah we where talking about kind of the same things when neotell launched without Ethernet connection and people wanted to know if you use to Ethernet with a use, and in that we saw and talked about that 2 from Ethernet to usb and back.
I was thinking of LAN over USB, but I didnt think even USB2 could go that fast.
I guess nowadays u can get anything to go via USB.
Anyways... is USB for a full time connection (serial/LAN/paralell) as good (stable?) as PCI?
If so, then USB->Serial should also be OK
