pfSense PPPoE configuration for OpenServe
georgelza
Johannesburg/Alberton
Hi guys
(realised this is not Axxess settings but probably, maybe rather Openserve ? as it's their network, although then... my login is a axxess username, anyhow)
Anyone running a pfSense (with PPPoE) device as their edge modem/router/fw with Axxess (and OpenServe)?
Looking for settings used.
G
Hello,
Have you done the pfsense basic setup? Setting up your wan and Lan cable?
If so then you just have to enter your pppoe details and it will be up and running with the basic setup.
He probably needs this (same for all local ISPs):
VPI 8
VCI 35
Multiplexing LLC-BASED
