PHP speed question
Thor
Bellville
Hypothetically,
Which one is faster in this specific example? I love regular expressions to bits, but just curious whether they should be used ALL the time.
PHP:
<php
		$value = "[email protected]";
		// preg_match is most flexible I know
		if (!preg_match("/@/", $value)) {
			echo "Validation failed.<br />";
		// strpos vs preg_match from a performance perspective?
		if (strpos($value, "@") === false) {
Languages have built in functions for the reason that they are usually well benchmarked and tested to make sure that they are the fastest way to it. Not always the case but usually is as they will be built at a lower level than your code.
It one thinks about how much work the CPU must do for something complex like processing a regex, vs something trivial like finding a character in a string, the situation is no contest. Regex's are very useful, but should in general be considered expensive, so use only when they avoid some other complex code.
Yea that is what I was thinking use regex only when truly needed as there is some pay off for its powerful ability.
If the only condition for your "valid email" check is to check for an @ sign, then strpos, if it's much more than that, then filter, if that doesn't validate a special TLD or something of the like you would need to specifically cater for, then regular expression
Here is your answer: http://we-love-php.blogspot.co.za/2014/03/strpos-vs-pregmatch-vs-stripos.html
strpos is faster.
Only use preg_match or any other regex matching when you cannot use strpos as you need to keep your code easy to read. While more experienced developers will easily read regex it becomes harder for more junior and even intermediate devs.
My work email signature: Some people, when confronted with a problem, think "I know, I'll use regular expressions." Now they have two problems.
If the only condition for your "valid email" check is to check for an @ sign, then strpos, if it's much more than that, then filter, ...
+1
...if that doesn't validate a special TLD or something of the like you would need to specifically cater for, then regular expression
Dear Lord, please don't ever use regex to validate domain. Have you seen the monster it is and you need to constantly update it. Then it only validates that it is a possible valid email domain.
2 years ago I had the problem with the existing regex being out of date so I tried MX lookups of the domain to rather validate it. Never went into production as we where concerned about performance but it was a proof of concept and worked well. If you ever really want to validate then there is only a few common domains (gmail, discovery, etc) that you could hard code into a list and then the rest you could do MX lookups.
strpos is faster.
:D
strpos is faster.
Shiat those stats!!
Holy hell. I really liked regular expressions since it felt natural and immensely powerfull.
Now I will try to never ever use it in my code.
Here is the email validation regex in PHP:
PHP:
/^(?!(?:(?:\x22?\x5C[\x00-\x7E]\x22?)|(?:\x22?[^\x5C\x22]\x22?)){255,})(?!(?:(?:\x22?\x5C[\x00-\x7E]\x22?)|(?:\x22?[^\x5C\x22]\x22?)){65,}@)(?:(?:[\x21\x23-\x27\x2A\x2B\x2D\x2F-\x39\x3D\x3F\x5E-\x7E]+)|(?:\x22(?:[\x01-\x08\x0B\x0C\x0E-\x1F\x21\x23-\x5B\x5D-\x7F]|(?:\x5C[\x00-\x7F]))*\x22))(?:\.(?:(?:[\x21\x23-\x27\x2A\x2B\x2D\x2F-\x39\x3D\x3F\x5E-\x7E]+)|(?:\x22(?:[\x01-\x08\x0B\x0C\x0E-\x1F\x21\x23-\x5B\x5D-\x7F]|(?:\x5C[\x00-\x7F]))*\x22)))*@(?:(?:(?!.*[^.]{64,})(?:(?:(?:xn--)?[a-z0-9]+(?:-[a-z0-9]+)*\.){1,126}){1,}(?:(?:[a-z][a-z0-9]*)|(?:(?:xn--)[a-z0-9]+))(?:-[a-z0-9]+)*)|(?:\[(?:(?:IPv6:(?:(?:[a-f0-9]{1,4}(?::[a-f0-9]{1,4}){7})|(?:(?!(?:.*[a-f0-9][:\]]){7,})(?:[a-f0-9]{1,4}(?::[a-f0-9]{1,4}){0,5})?::(?:[a-f0-9]{1,4}(?::[a-f0-9]{1,4}){0,5})?)))|(?:(?:IPv6:(?:(?:[a-f0-9]{1,4}(?::[a-f0-9]{1,4}){5}:)|(?:(?!(?:.*[a-f0-9]:){5,})(?:[a-f0-9]{1,4}(?::[a-f0-9]{1,4}){0,3})?::(?:[a-f0-9]{1,4}(?::[a-f0-9]{1,4}){0,3}:)?)))?(?:(?:25[0-5])|(?:2[0-4][0-9])|(?:1[0-9]{2})|(?:[1-9]?[0-9]))(?:\.(?:(?:25[0-5])|(?:2[0-4][0-9])|(?:1[0-9]{2})|(?:[1-9]?[0-9]))){3}))\]))$/iD
source: http://emailregex.com/
PHP:
I know this.
Read the post where I said I AM NOT using that as validation or anything I DO NOT use that code it was merely for illustrative purposes
Shiat those stats!!
Once off usage is rarely ever going to an issue e.g. email validation.
You should only be looking for faster alternatives when you're, for example:
  • processing a large dataset in a loop.
That's what I currently used it for hehehe.
In the loop I am removing some pipes and funny character from a string begotten from the api loop runs for 300 currency items lel.
Clearly not efficient so I'll be "optimizing tonight"
300 is not large. You're wasting your time.
As @biometrics said; don't bother, that's definetly not large...
When in doubt remember this:
"Programmers waste enormous amounts of time thinking about, or worrying about, the speed of noncritical parts of their programs, and these attempts at efficiency actually have a strong negative impact when debugging and maintenance are considered. We should forget about small efficiencies, say about 97% of the time: premature optimization is the root of all evil. Yet we should not pass up our opportunities in that critical 3%." -- Donald Knuth
http://c2.com/cgi/wiki?PrematureOptimization
Each loop irreteration takes 384ms
So 300 x 384ms
Then the regex takes 0.025ms
So it's 300 x (384 + 0.025)
I can't do anything on the API speed but I can use something else instead of regular expression.
