Plasma to PC Help
RVFmal
Want to connect a plasma screen to a PC to run a presentation in offices.
PC is a workstation and need to be able to run presentation on plasma whilst still working on PC. Aside from Power Point, what other programs can we use for this?
The machine is in the middle of the office and by my calculation we will need 15 to 20m of cable to get to the plasma. Does a DVI cable come in that length and if not what other option is there to connect the plasma to the PC?
Yes you can get a VGA and DVI cable in that lenght. They are expensive though.
